I got the plane all together and threw 2x 3S packs in series in her and throttled up...LOTS of oscillation at anything above about 25% throttle
I think the struts on the new ducts are just too thin and with the amount of thrust 6S is putting out they are moving a bit. I was attempting to swap the props in order to see if it was at all related to the slight curvature in the struts and I damaged the one motor trying to get the prop nut off
Then while trying to connect to BlHeli to reverse the motor directions and I got a nice flash from the FC while plugging the battery in, strange bc I had not touched anything physically on the FC when it happened.
So my A10 is back to hangar queen status. I think I will try to model some new ducts that use the beefier design like Drone5 and incorporate more cooling similar to the BDFs and Chris398mx designs. I will also need to figure out what FC I am going to put into this plane to get it back up and running.
