I flew my Tutor for the first time yesterday! I flew with a C pack, a 1300mah battery, floats, and the sport wing.
It got off to a bumpy start due to COG issues. I had it balanced at the marked locations and a touch nose heavy. To get it to balance, I had to move the battery all the way under the windshield, mounted the ESC at the far rear of the pod, and mounted the receiver back in the tail. After all that, it balanced nicely. However, when I flew it, it was clearly tail heavy. I ended up moving my battery three or four inches forward, so that it was under the removable hatch. After that it flew pretty nicely. I saw somebody else had a similar issue. Either the COG changes with floats, or there might be an error in the plans. I won’t be able to test with wheels for a couple months, so I can’t say. Regardless, other than an exciting first flight, it’s behaving pretty well now.
Another issue I had was that my floats started coming out after a couple aerobatic maneuvers. The rear came loose and the front of the floats got chewed up by the prop. Fortunately I managed to land it and there was no damage to the plane at all. A couple pieces of packing tape and I was flying again.
The last issue I had was that the rear of the wing, where it’s a single layer thick, folded up due to the rubber bands compressing front to back. The same thing happened on my Storch, so it was easy to fix with some extra foam filling the gap. I wonder if this had anything to do with my COG issues since it changed the angle of attack on the wing, and maybe move the center of lift?
Oh yeah, one more issue I had during building was that my power pod didn’t fit. It was about 1/16” too wide. I didn’t fold the power pod wrong (it matched the FT firewall that I used) and I did remove the paper from the doublers. Maybe I didn’t compress the doublers well enough when I glued them on, although there is no visible gap. Regardless, it was fairly easy to fix by cutting 1/16” out of the middle of the power pod template and also sanding 1/16” off the firewall.
All that said, it flew fairly well after a couple teething problems, and that was despite a windy day and flying with floats for the first time!
