Drone 5
The undercarriage in the wings were bent as per the pics of Nerdmampap, posted March 20th and sandwiched between 2 pieces of foam and then that was stuck onto the motor nacelles. Extra wood support was then fitted. The wire attached to the underside of the wing was saddle clamped onto ply and 12mm square blocks were added to the underside to take the screws. The paper was removed so that the ply could be stuck direct to the foam. Also cut outs were done in the wing so the 12mm blocks could sit inside the wing cavity.
The front nose leg was done similar but a piece of 25mm EPP foam was glued inside to fuselage. See pic. The wires were tied with thin wire and then soldered.
Hope that helps.
Hope that helps.
