L Edge
After having good luck using Readi-board to build 3 planes, decided to see if a SPONZ "wonder" could be adapted and fly as well as his.
Redi-board is 30" x 20". So using my last version of Wonder that can slow fly, hover, and handle high gusty winds,
decided to make one that uses 1 1/4 sheets!!!! That's about $1.50.
So it will be off-scaled and performance is what I am after. I am looking it to be light, handle slow and fast speeds, be acrobatic, land in crosswinds, and most of all, handle nasty winds like my other.
So wing size is 30" long by 10 and 1/2"wide. The back section is 8" wide and depth is 9 1/2". This is the underside and used a pen for the centerline. Should use tape to put it together on front side and then open and fill with hot glue and lay flat till it's cool. Wipe off excessive glue.
I am using endplates on wing and elevons, So you can see above is a cut out one wing endplate and papered the design of others to show I now have used a dollar sheet and the only thing I need is narrow strips to make the fuse.
With the fuse going down the center and 2" wide, the tail section will be strong enough with endplates. The endplates on the wing will reduce twisting and to reduce bending, I am going to use carbon fiber strip that is glued on to the underside. See pic 1.
All one needs is to first draw your line with a pen where your placing your carbon strip. Next, take hot glue gun and run a bead on the pen line. Now apply the flat carbon rod to the foam and I press a 24" metal ruler over it and let it cool. To insure a good bond, I use my Monokote iron (temp is 280 F) and iron back and forth where the glue is re-melted to the foam paper. Press the ruler firm and you will have to use quite a force to ever get it apart. This has been tested on 2 other redi-foam planes..
