So I built a FT Versawing for my first plane.
My first dozen flights were mostly crashes as I worked through a series of rookie problems with slipping control linkages, center of gravity, and a few other things. As a result, I've gone a little overboard on strengthening the thing with extreme packing tape, tongue depressors, and lots of hot glue. Including motor, and prop, and quite a few lead weights on the nose it now weights roughly 750g plus another roughly 250g for the 3s 35c 2200mah battery, with a slightly nose heavy COG.
Through all the test flights so far, one challenge has been finding a place without too much wind (SF is very windy). My last few flights in relative calm, I definitely had control authority and was able to fly 150 feet or so despite a few gusts, but could not gain altitude much above 20-30 feet, despite having throttle at full and trying to pitch it up.
I'm thinking I was too conservative on the power system - I used the FT powerpack B, which comes with what the site says is an Emax CF2822 and 20amp ESC. I don't know exactly what KV the motor is - I don't have the box for the motor anymore, it's not marked, and googling the model number yields a few different possibilities, but it seems like 1200kv? I've been using an 8x45 prop (balanced).
Any recommendations on a more powerful motor? From reading and youtube, it sounds like I might want to consider something in the 1500-2000 kv range, with a smaller prop and probably higher wattage ESC? Any suggestions on particular pairings for something like this?
Any other suggestions or thoughts for this project also appreciated...
