Vimana89 Arrowhead Tailed Delta(Tried and Tested, Plans Released!)
Which name is best for this plane?
  • Easy Ace
    Votes: 0 0.0%
  • Tree of Lift
    Votes: 0 0.0%
  • Arrowhead
    Votes: 3 100.0%
  • One Sheet Wonder
    Votes: 0 0.0%
  • SBTD(Super Basic Tailed Delta)
    Votes: 0 0.0%
  • Other/Your Own Suggestion
    Votes: 0 0.0%
  • Total voters
    3
  • Poll closed .
Vimana89
Just a quick question for my V-Tail build, you said something about thrust angle a while ago. What should the thrust angle be on this? I didn't have any on mine which probably is the source of all my problems.
The thrust angle should be the same as you would for any tractor prop configuration, a tiny bit down and right(not sure the exact degrees, I usually eyeball it and can differ a tiny bit on plane and motor). Maybe for reference print out and/or use the FT power pod for a tractor mounted motor, it should have thrust angle on it like it does in kits,but I'm not sure.
Crawford Bros. Aeroplanes
I think Grifflyer said earlier on this thread 2° right and 1° down
