leaded50
well, my neighbor is a pro car painter..... ive been worked with airbrush/lettering/striping/ signs , custom paint in years before...U do no how to give FB a nice smooth flow, that's for sure.
Cool. When I get to glassing my current project, I will hit U for tips.well, my neighbor is a pro car painter..... ive been worked with airbrush/lettering/striping/ signs , custom paint in years before...
have you considered just printing a standard paper printed version? using glue to wet it and set it up like a normal decal? not a seamless, but it sure does work for me sometimes. (esp, on intricate items)well...yes!
Was and checked pricetag on decals (the Virgin logo) today... far too expencivebut have another place with friends who gives me good deals.... they are on holiday though.. If not, i will pick up the airbrush and make it my self.
well, its the same company who have holiday who use to make my paperprints toohow you considered just painting a standard paper printed version? using glue to wet it and set it up like a normal decal? not a seamless, but it sure does work for me sometimes. (esp, on intricate items)
Airbrushing pluss a little extradid it, without very much work!
Used a mask to make approx a round blue ring.. then airbrushed the black center. After airbrushed out white "stripes/beam" and more against the black... then used a paper towel to drag out the white airbrushed "stripe/beam" paint close to started drying.
Maked the letters with a lettering brush, and when coated with clear varnish... its ok !!
View attachment 204499 View attachment 204502
well.... been funWow, looks amazing! Any plans to build the carrier aircraft White Knight?
when i bought my first "pro airbrush" after used a cheap one a while... the easiest to get was Badgers here locally. And a local paint supplyer gave me a "good" price (very expencive anyway) 2 weeks delivery direct from Badger. I was 19 y. old. (needed do a airbrush job for them though) I took long time, before really learned using its potential.Thanks @leaded50 . That last line in your reply is so true as well as the one about the tool and who is using it. Considering how well the VL worked for me, I am going to pull the trigger and order the Talon from Midwest Airbrush Supply today.
larger compressor/tank was more depending on what work you use to do normally, and what you could get of equipment to a reasonable price. Also todays paint equipment is setup for lower airpressure than earlier, even if not much differences by airbrush though, but even touch-up airguns uses lower pressure than used normally before. . My self used also a 15 litre tank, 0.25hp electric compressor before got the dentist chair compressor. That compressor is tiny (but pretty heavy anyway, a lot more queit... and superb quality. And new that costed a lot more than anyone for painting.... far better quality. Ive changed one bearing only at it. in all this years, and was used when i got it.
What should get first...... you know, its a lot of techniques to use in painting who make stunning results.. even without a airbrush..![]()
N I C E gutiar!! and it shows... its not only airbrush eg who can do the trick on beautiful colorsIf this is in reference to my previous comment the reason for the big tank and compressor is they ran air grinders and sanders as well as air brushing work in the shop. There was a main line running around the room with taps that had remote located regulators and water / oil filters for each of 5 stations. I was out shopping yesterday and looked at a small electric compressor mounted to a 5 gallon tank that is more in the normal realm for a home system for a hobbyist painter. Just not sure I want to bother with RC stuff anymore after seeing the new attempt by the FAA to kill the hobby. Just trying to keep up with what they are trying to do is too bothersome at this point.
as for had painting stuff... this isnt paint but it is all hand stained, hand sanded, hand polished from my latest project.
