what is the slowest plane on FT
Rasterize
Maker of skins and decals for foam board RC planes
Progress! ....and a really long post.
The only part I think there may be questions on is the following: This is what I call the Power Pod Cradle or the PPC.
There are two sides and a bridge. This is how it looks in the plans:
Each side of the PPC is made up of three pieces for 6 total. Here is what the pieces should look like cut out. Note the red outline on the far right piece. This area has the foam removed per the plans. It has also been pre folded with the two pieces to it's left. The red arrow at the bottom points to the crease line. This paper will wrap each side so when you insert the power pod there is nothing for it to get hung up on.
The third and final piece of the PPC is the PPC Bridge seen below with a standard C Pack Powerpod. The PPC Bridge will span the two fuse halfs providing dimension and strength (tabs sticking out the edges key into the fuse). The sides above will be glued onto it's edges (they key into notches on the sides). There are slots for the power pod to plug into (outlined in red).
Here is the Power Pod sitting in position on the bridge with the C fold completed. Below it, one side (3 pieces) has been glued together. The edge wrap has yet to be glued in position.
One side has been glued in position. The other side has been assembled and the flap is glued down. Make sure you don't accidently glue the power pod in the cradle!
Second side ready to be glued in position. Note how the open sides go to the outside, away from the power pod.
Cradle with power pod assembled.
Power pod should easily slide from the cradle.
Tabs on the side of the cradle will then key into slots on the fuse. Slots (in red) have yet to be cut.
Once the cradle is glued to the first fuse side, it would be a good time to make your skewer holes for that side.
Cradle installed (sans powerpod). The rest is just fuse panels and wings!
Clear as mud? Goooood.... :)
buzzbomb
I know nothing!
The only part I think there may be questions on is the following: This is what call the Power Pod Cradle or the PPC.
Here is the Power Pod sitting in position on the bridge with the C fold completed. . Below it, on side (3 pieces) haves been glued together. The wrap has yet to be glued in position.
Ones side has been glued in position. The other side has been assembled and the flap is glued down. Make sure you don't accidently glue the power pod in the cradle!
Verrrrryyy slick!
sundown57
ill try printing them tonight when I get home.
I wanted to mention an easy and great way to support the wings on larger builds like this is to cut the leading and trailing edge about 1 1/2 inches longer than the plans call for. then score cut them back to where they belong. that way you can run a skewer the full length of the wing both front and back. then you can just roll the paper over the skewer and hide in underneath the wing so it doesn't show. that keeps the leading and trailing edge very straight and strong.
sundown57
ok, so this is how I have been cutting the wings and adding the skewer. I do the skewer before I peel the paper or start to roll it. that way I don't get any wrinkles in the edges. and you can see how I leave just a small amount over the edge to tie the string to.
sundown57
@sundown57 - I was tidying up a flight log thread, and the very first video from a year ago is the fish flying slow - brings back memories of you starting out too! :D
Yeah, that fish and that time frame was the real turning out for me. that's when I knew I could learn to fly. I hadn't had much luck until then. I had built mostly all mini's not knowing that larger planes were easier to fly.
Rasterize
Replacement page for Page 4 of the "Slowfly Ltr Body.pdf" on post #300. Slots are missing and off center on page 4. Also the vertical lines on the back of the fuse side should be a score line NOT a cut line. I will put up replacements later. Thanks to sundown57 for the catches!
  • Slowfly Ltr4.pdf
Rasterize
Replacement pages for Page 18 and 22 of the "Slowfly Ltr Body.pdf" on post #300. The vertical lines on the back of the fuse side have been changed to a crease line NOT a cut line. Thanks again to sundown57 for the catches!
I will update the "Slowfly Ltr Body.pdf" on post #300 as soon as I can.
  • Slowfly Ltr18.pdf
  • Slowfly Ltr22.pdf
sundown57
I'm not too far behind. I have the fuse, power pod, tail and wings about done. hopefully tonight I can finish mine up. I love the eyes on yours, amazing how that little bit can give it so much character.
Rasterize
That's just awesome! Absolutely love it! The little mouth sticker just makes it work! :love:
Thx buzzbomb! My wife and daughter said the face really boosts the "cute factor". lol
Sweet! Love the over sized wheels. Waiting for a video :)!
Thx Mayan! They are "Bushwacker style" wheels. 20" in circumference! Covered in black packing tape with some cool steel wheel graphics on the side.
Looking good boss! I'm a way slower builder. A few minutes here, a few there kind of thing. I'm hoping to maiden tomorrow morning.
The googly eyes are right out of my local Walmart craft center. I like to peruse it for odds and ends, popsicle sticks of various sizes, wooden dowels, googly eyes etc.
