In general and in my opinion, small, light copters built with quality parts are less expensive over time than larger copters or copters built with cheap parts.
Small, high kv motors vibrate less than large, low kv motors and use shorter, less expensive rotors that also tend to vibrate less than longer rotors.
Light copters break less than heavy copters. Chaos taught us about large acro copters with The Beast 666.
Earhog teaches us about light acro quads:
https://www.youtube.com/watch?v=IKUevXyzf88
My favorite today is the Twitchity Hex.
http://forum.flitetest.com/showthre...build&highlight=cranialrectosis+twitchity+hex
I have flown a 3000 mAh lipo with it and it did just fine. This copter has thrust-a-plenty when you put 2204s on it and run HQ 6030 or 6045 rotors.
Of course, I srtipped mine down to < 398 grams + lipo to get the MOST power to weight and the thing hovers at <> 25% throttle. It is an acro monster, comparable to a WarpQuad, it can flip roll and haul @$$.
I smashed my Polakium hex and am rebuilding it today. It broke in part because I was flying a heavy as heck 1800 mAh 4S lipo when I muffed a flip.http://forum.flitetest.com/showthre...-build&highlight=cranialrectosis+polakium+hex
In similar crashes the Warpquad might stick in the ground but other than needing to clean the sand out of the motors, you aren't going to harm a Warpquad. The Twitchity frame made a kind of 'booiinnnggg' sound and I had two broken rotors and two motors full of sand. No damage to the frame.
You can tame the Twitchity Hex with 1806 motors and 5" rotors or you can turn it into a rocket to Mars with Cobra 1960kv motors running 6" rotors on 4S. Don't expect to lift an SLR but FPV gear and a Mobius are no problem with the proper 'beef'.
No other multirotor on earth flips quite like a WarpQuad, but if you want the ability to go fast and carry some gear with a lightweight, tough kit, the Twitchity Hex is a pretty versatile frame.
