baronbernie
Using masking tape can be used but will tare the paper and plans. Use the blue painters tape instead as it comes off without peeling the paper off or ruining the planes.
That depends on whether you can deal with folds or if they would have to be rolled! lol
I did get some plotter paper and the initial tests went well. But some of the pdf's seem to have corruptions in them that the plotter does not like. I'm going to see what I can do to fix that but shipping the prints might be cost prohibitive, unless your local place is charging over $10 a print...
I don't mind helping out fellow pilots but it takes time to make them right. I can't print them for free...I can probably do them cheaper than most places when it's all said and done, but again, shipping is going to be the issue.
Just wondering what your methods are for getting the plans from paper to your foamboard? Have you tried different methods? what worked, what was horrible?
If I'm not mistaken, those wheels are designed to be used in conjunction with a pounce pad or chalk bag. Trace with the wheel to get holes in the plan then pat the outline with the pounce pad after you put the plan over the foamboard. That will leave behind your outline without deforming the foamboard, plus you'll only have to trace once and can use the plan over and over. You can probably make a pounce pad by putting marking chalk into an old sock. Make different color pads and you can make the fold lines and score lines different colors than the outlines.
Either way should work. I'm sure you'll be able to see the perforations with no trouble.Yes that is how they are used in sewing. I was thinking since they are meant to poke through the paper to create holes for the dust in the pounce pad, it would do it to the paper of the pattern as well as the foam board (a sharp one). I am hoping the powder would not even be necessary with a sharp pointed tracing wheel.
I don't know if anyone has tried it yet, but I am going to try a sewing tracing wheel....
