I'm not entirely sure what the standard is for channel order, I'm not sure if there actually is a standard. So here's a thread to compare what channel orders you use. (List all channels that you use)
For me:
4 channel planes:
1/2: rudder/elevator (often switched and not consistent from plane to plane)
3: throttle
4/5: right/left aileron (again, often switched and not consistent from plane to plane)
(sometimes throw a knob in for flaperons, or on my FT3D I have a switch to mix the elevator into the ailerons to make spoilerons/flaperons depending on what the switch is doing)
3 channel elevons:
1/2: elevons (again, no set order for right/left)
3: throttle
So in my case, I really don't follow a standard aside from throttle on channel three. And the order often gets switched around every time I pull the receiver out.
For me:
4 channel planes:
3: throttle
3 channel elevons:
3: throttle
