Hey all,
New here on the forum, but not new to building Flite Test models and watching these great videos. Learned I lot this way!
Models build so far (in this order):
I started of building with foamboard (F-22 and Racer). But the Dutch foamboard is rather heavy. The F-22 Raptor managed, but the Racer turned out to be too heavy.
Since then I’ve been using Depron (like) foam (3mm and 6mm thick) laminated with wing tape. In the beginning I first laminated a whole sheet of foam before cutting (like Experimental Airlines), but often this would curve the foam. So now I first cut out a piece of the airplane before laminating it. This works fine for me. I use both hot glue and Clear Foam Glue (Hobbyking) building the plane.
As a new project I would like to rebuild the FT Racer (love the looks of that plane), but scaled to 120% size. Since I am building with 6mm foam, I only need to print at 120% and that is it.
For the motor and propeller combo to use I would like your advice. The other FT Racer flew of a Park480 (1320kV) and 8x6 prop. But I presume this will be too small a motor and prop for the 120% Racer.
What kind of motor and prop size would you recommend? I prefer to use 3S 2200mAh batteries. I also have a couple of 6S 3300mAh batteries (from my T-rex500) which I could use. I do not own 4S batteries (yet…).
Open to your suggestions!
Best regards, Martijn
- FT F-22 Raptor
- FT Racer
- FT Mini Mustang
- FT Arrow
- FT Tiny Trainer, for teaching my son to fly
- FT Super Bee
- 120% FT (not so) Tiny Trainer, as a replacement for the other FT Tiny Trainer
