Willy Nillies
Most excellent Ted! Glad you are having fun!!!
Sincerely,
Doug and Becky
WillyNillies.com
Sincerely,
Doug and Becky
WillyNillies.com
Jim "eliworm" is local to me and after seeing his son and daughters flying the Q-Tee I had to have one. It just took me way too many years to finish such a simple build. Jim cuts really nice kits. The Q-Tee still sits with 6 other planes waiting for maiden but it's just too freaking hot to go outside.
Joe
I also had another idea. What if I kitbashed one of these into a true low wing? That'd be kinda cool...
You can use tons of materials on these airplanes. Ultracote, monokote, doculam, solite, solarfilm, parklite, tissue paper, silkspan, you name it; everyone's tried just about everything. Depends really on how much work you're willing to doWhat should someone be using for covering on these models? Will the Cover Packs make me happy?
Fuselage covering is done with the exception of the underside (because I need some way to put the gear on...) Unfortunately I couldn't get the curvature exactly right on the stripe on both sides. This is the better sideNow that it's done I'm going to stick the tail feathers on soon after I hinge all the control surfaces. I'm thinking of using fishing like on this instead of CA hinges but we'll see what's easier to do...
Now it's time to build some wheels. I wanted some WWI style wheels since that's what most Pietenpols have but sadly Williams Bros smallest wheels are 1 7/8" which is kind of useless. So I guess I have to do this the hard way...
These are the four halves, to make two wheels. I cut them from the lightest 3/16 balsa sheet I had.
Then mounted them to some dowels to put them in the poor man's wood lathe known as a drill press to turn them true and sand to shape. This creates craploads of sawdust, so keep a shop vac close by. At this stage I only round the edges and add the rough conical shape with 100 grit.
At this point I removed the dowel with acetone, added the aluminum tube axle and secured it with epoxy thinned with alcohol. Then I can mount it to my Dremel and use 600 to 1000 grit paper to really get it smooth and symmetrical. This is test fitting the O-ring tire. I'll secure it probably with canopy glue one I get some since CA would leave it all ugly and white. After this stage I further increased the angle of the cone shape to thin the outer edge of the wheel more so it doesn't stick out as much from the tire.
And here is a completed wheel, sans tire glued, next to a wheel in between being shaped with the drill press and finished with the Dremel. I just covered it with the same monokote I used on the fuselage, though I did consider painting it instead.
Tomorrow comes the fun part. Building some landing gear. Then it's maiden time!
The landing gear appears to have a slot-and-peg style thing going on. There was a bulkhead with a triangle etched into it and there were 2 triangle-shaped pieces of balsa that matched the etch. I glued them to the bulkhead and then glued another bulkhead atop those. The gear fits into the socket and a final triangle-shaped wedge will push down into the socket to hold the gear in place.
Epoxy is not needed to rebuild the cabane struts. Thin CA will do the job just fine, and be lighter. I would imagine they are not a difficult part to scratch build either, should that be easier. Did you break them by trying to insert the dowels that go across between them? I almost did that but decided to just ream out the hole slightly so they would fit without binding as badly.
Usually, the gear wire is secured to its bulkhead before it goes into the fuselage. Doing it this way probably won't cause anything bad if you rethink the steps correctly, and it might also make the fuselage easier to handle during building with no gear wires stuck out the bottom. I wouldn't really know - on so far every Willy Nillies build I've done I ended up abandoning the standard gear setup and doing something custom
Did you put the controller under the turtle deck before you glued it? I almost got caught out by that. For the turtle deck itself on my build I ended up using lighter balsa because I found it worked better when I rounded it off around the motor mount. Plus I wanted to use one continuous piece and the included one wasn't long enough.
I understand exactly what you are describing. That's a clever way of assembling the landing gear. I put it all together before assembling the fuselage but your way will work too. 😎👍
