mastermalpass
Here it is! After over a year in development, the HalfPipe and HalfPipe - Delta are now available!
RC Flyers crash... Beginner flyers crash a lot! Crashing is an upsetting and off-putting hurdle that all beginners must face in order to build their skills to a level at which they don't crash (so often). The HalfPipes are 'disposable' tough planes to help beginners feel less bad about crashing and develop their skills with confidence. They can be set to be easy-going gentle flyers or have their rates set to max and become super agile stunt planes. On 2S and with the throttled kept low, they can fly at a jogging pace. When given a 3S battery, the power is simply overkill and they can scream through the air. As your skills develop, you can effectively increase the difficulty level; hone in your reaction speeds and stick-precision before making the leap to more 3D-flying models.
I hope these designs will give beginners the easy and forgiving introduction to the hobby that I aimed for them to. And I also hope that more experienced flyers will also get much enjoyment out of one of these designs. This is of course my first ever release, so feedback will be much appreciated. Thanks in advance to anyone willing to have a go at one of these and do not hesitate to ask questions if you have any!
Special Thanks to @mackaiver for building this model early access and entering it into the Rigorous Testing Program.
Important note: these designs are based on 6mm Depron foam - Flite Test foam is 5mm, so cut your slot-holes a millimetre slimmer if you're building with it!
Recommended Expo: 30%
Download Links:
HalfPipe: Full Plan
https://www.mediafire.com/view/yw1tvh5k8lg62g5/Half-Pipe-Full_plan_Full_plan.jpg/file
HalfPipe: A4 Tiled Plans
https://www.mediafire.com/file/3g2pmf4rdvhkrag/HalfPipe_Tiled-Plans.zip/file
HalfPipe - Delta: Full Plan
https://www.mediafire.com/view/a1bfp44gwq75dwh/Half-Pipe-Delta_Full_plan_Full_plan.jpg/file
HalfPipe - Delta: A4 Tiled Plans
https://www.mediafire.com/file/xx2vjtuna6h3nkk/HalfPipe-Delta_Tiled-Plans.zip/file
HalfPipe: Build Manual
https://www.mediafire.com/file/nl4jsituhcxgvyp/HalfPipe_Build-Manual.pdf/file
HalfPipe: Flight manual
https://www.mediafire.com/file/l4sjdxm7sd3y0zh/HalfPipe_Flight-Manual.pdf/file
HalfPipe Delta: Build Manual
--- To be Created ---
And on final note: Admin, I don't have permission to post new threads in the community releases forum. I would be very grateful if you could move this thread over to it.
Cheers!
- Will, of WingMill RC
Download Links:
HalfPipe: Full Plan
Cheers!
