Looking pretty good. hands are a bit over-sized but you could claim gloves are on them. I think it would be better if the print layers were smoothed out and incorporate some washes. Don't take my comments too hard... I'm a perfectionist and I'm always critical as a result. Your pilot is far better than what comes from Hangar 9, which is saying something. H9 makes good stuff.
I actually made progress last night. The first step is to take your panel lines and plan out how you are going to layer the panels. Keep in mind that there is overlap. Panel lines are created by this overlap so you end up applying the panels in sections. It seems tedious at first but let me tell you, the sectioning actually makes things easier. With my panel lines drawn, I applied some tape factoring in about 3/32" overlap. 1/16" seemed too small and 1/8" was just too much. As most of you may know, I prefer metric, so I'm using 2mm of overlap.
For the sake of saving some content for a video on this process I'll do a high-level overview of what I've done. Panels were overlapped (typically) by a forward panel. Therefore you apply panels from the aft moving forward. I applied foil to the area in the rear using only a clean and soft paper towel as a smoothing agent. The edges where the tape serves as a barrier was cut using a #11 razor blade and the excess was removed. The second panel in the middle was then applied in the same way. The front panel proved difficult using a paper towel. I ended up wasting 3 sheets of foil on this area as I conceded that I needed to use my burnishing tool. Having some experience on my prototyping of my process, This does create some scratches in the foil that I will need to work harder at to remove through polishing. The reason for the burnishing tool is that it applies the foil in a smaller area at a time while stretching the foil, allowing it to go over the compound curve without wrinkling the foil. In all, the taping and application of this area took about an hour. It is a SLOW process but I am also new to it. It's highly likely that I will be more proficient at it by the end of covering this project. Overall, I'm fairly pleased with the results. It has been a very busy couple of days so I was tired and I will likely go back and massage a few areas.
