Hello Erveryone,
I have the very same Yak. First, I wanted to shout out that it is the best Plane I ever had! I would recommend it for everyone who want's to get into 3D flying or already had a plane that got beaten up on the first couple attempts (like mine).
My Settup
2212 1400kv Motor
9x5 GWS Prop with prop-saver (I would definitely mount a prop-saver!)
850 mAh 25C 3S to 1300 mAh 20C 3S
20A ESC
About 500 gram
It pulls about 22A on that setup and the flitetime is about 6-10 mins, depending on the Lipo your using. I didn't measure the thrust, but it is more than enough. While hovering you'll need about one half to three fifths of throttle and there is plenty of power to climb vertical after a nice hovering action.
I tested a 850 mAh, 1000 mAh and a 1300 mAh Lipo. The sweet-spot is probably the 1000, because the plane balances out very good and it doesn't add to much wight. With the 850 mAh it is a little bit tail heavy and with the 1300 mAh it is a little bit heavier and therefor not as slowly to fly...
I'm very satisfied with the setup and would recommend it to everyone! I think it is just the best balance between Power and wight!
Hope I could help you,
good luck
Martin
