Hard to stay away when it's this close.
Rudder is now functional, though 1" foam presents some issues with clearance. There are some interesting angles involved to make it swing a full 45* each direction.
All still blocky, I'm leaving sanding till all the interesting problems are solved.
After some reading and thought, I decided to go experimental on the airfoil and build a KFm3. Based on the info I could gather, this variation is great for heavy lifting and known for a very slow stall speed. Sounds perfect.
Figures are 12% thickness, steps at 50% and 75%. I decided at the last moment to extend the ailerons out another inch and extend the chord to give more roll authority. The plans weren't written for 1" foam and the ailerons just didn't seem to give enough down travel as designed taking thickness into consideration.
It was tricky to rip the foam thin enough for the steps. I ended up having to clamp a make shift fence onto the band-saw and slowly split 2.5" wide strips to .5" and .25" (the saw guard is only 4.9" tall, so the 50% step being 5" was a no go in one shot). The front (left) piece here is only taped on here as I am going to figure out a way to route the motor wiring under it before I glue it down permanently.
Keeps looking more like a plane! Still pondering the elevator solution...
