OutcastZeroOne
Fly, yes... Land, no
So its been a while. Been working on a few deisgns since the move. Still getting stuff unpacked but I had the urge to build.
I give you my YF-244 Caiman.
223g flying weight
AX 1806 2500KV motor with 6x4 prop.
750mah Rhino 3s pack.
20" wingspan, 20" length
I bult this one a bit different. I didnt use any tradition wing spars. I started off like I normally do, by removing the paper from the Readi-Board. Where I live there is enough water in the air that it softens up the bond of the kraft paper that comes on the foam board and seperates it off. I dont have to use anything to peel the paper off, just get a corner started and pull.
I then used some good quaility 20lbs paper and glued it back onto the foam board, just the center layer of the wing, top and bottom. Lots of stiffness and the rubber cement holds the paper on beter than the OEM stuff
Have yet to fly it. should be a rocket though
223g flying weight
