Long EZ 24" Wing Span
Plane Long EZ 24" Wing Span V2
Please log in to download
Type
Build Plan (PDF, AI, etc.)
This is based on the FT Long EZ and @jpot1 's ideas scaled up 125%. It has KF airfoils on the wing and canard along with an elevator on the canard. It's an easy build but a fast and nimble flier - I wouldn't suggest if for your first or second plane. You'll find that just like a real canard aircraft this has a very gentle to nonexistent stall.
You need:
2 sheets of FB
a couple of BBQ skewers
"F" power pack or equivalent
3S 850 battery
3 5gram servos & arms
1 FT mini control horn
2 FT swappable size control horns
And not necessary but I like the hatch lock available here: https://airc-pirates.com/hatch-lock/
Build tips:
Spend time getting the fuselage square and straight then your wing and canard will line up and be parallel.
Tape the outside and inside of the hatch hinge.
Put on the canopy, top rear, bottom front skins and the Velcro for the battery before attaching the wing or canard.
The bevels for the ailerons and elevator can be on the top or bottom, as you like. I put mine on the bottom.
Preflight:
To start set the ailerons for 15° and the elevator for 30° deflection then tune to your taste.
This is a canard so when you pull back on the stick the elevator should deflect DOWN not up.
Here are build photos but don't hesitate to contact me with questions.
IMG_3820.JPG IMG_3821.JPG IMG_3822.JPG IMG_3826.JPG IMG_3827.JPG IMG_3828.JPG IMG_3823.JPG IMG_3824.JPG IMG_3825.JPG IMG_3829.JPG IMG_3830.JPG IMG_3831.JPG IMG_3832.JPG IMG_3833.JPG IMG_3834.JPG IMG_3835.JPG IMG_3836.JPG IMG_3837.JPG IMG_3838.JPG IMG_3839.JPG IMG_3840.JPG IMG_3841.JPG IMG_3842.JPG IMG_3843.JPG IMG_3849.JPG IMG_3846.JPG IMG_3845.JPG IMG_3844.JPG IMG_3848.JPG IMG_3847.JPG IMG_3850.JPG IMG_3851.JPG IMG_3852.JPG IMG_3854.JPG IMG_3855.JPG
Author
Mr NCT
Downloads
100
Views
2,353
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from Mr NCT
Latest updates
  1. LongEZ V2
    Changes: Thickened KF airfoil for more lift Added slot for bbq skewer at the front of canard...
