Control Surface Protractor
Part Control Surface Protractor 1.2
Please log in to download
Type
I was tired of searching for throw gauges or printing new ones. This protractor is 2 1/2" per side so it's small enough to measure control surfaces and can go positive or negative. It has major divisions at 10° and minor at 2°. I made the outside so that it easily pinches against the inside to hold your angle. The one in the picture is printed in two filament colors using Prusa Slicer.
Printed in PETG with 25% triangular infill - though I don't think it really matters. The pivot is an M2x12 screw & nut. The inside piece prints flat, the outside piece prints vertically with supports (organic if you're using Prusa).
Author
Mr NCT
Downloads
53
Views
2,138
First release
Last update
Rating
5.00 star(s) 2 ratings
More resources from Mr NCT
Latest updates
  1. zip with all parts
    Outer, inner without numbers and inner with numbers
  2. Inner part with numbers
    Playing with 'engraved' numbers.
Latest reviews
This is a truly amazing tool! I didn't have any M2 hardware lying around, so I bent some landing gear wire for the hinge. Works great!
Another "where'd you get that?" for the field box.
