- Type
- 3D Print Files (STL, G-code, etc.)
I needed a larger radial for my golden age planes and was inspired by @SP0NZ radials. This one is in two pieces - the case & cylinders that allow for a motor with X mount to be attached from the front and the cover then snaps over the top. It's designed for FT2218 but should be easily modified for other sizes. When printed with PLA and 15% infill it's 100 grams but the infill can be varied for more nose weight. I'm including stl and step files.
