With the first window in place I couldn't resist pushing forward and covering the side. The major goal was to avoid wasting too much covering since it's fairly expensive. Some careful-ish measurements tell me that if I'm lucky I'll get both sides covered from a single length of covering at 54" long. Hopefully. It took a little work, but I was able to get the elevator and rudder pushrod holes cut very close to where they need to be (to avoid big ugly holes in the covering).
I covered the side (including the windows) with a single sheet of covering, so no seams to worry about.
After shrinking the covering I sealed the covering down to the extra plastic around the windows and then carefully cut the covering off to expose the windows. When shrinking I had to be sure to keep the heat AWAY from the windows so I didn't accidentally stick the covering to the clear windows. That'd be bad... I'm super happy with how it's looking so far!
