Well, so much for the pinking kit being enough for a 1/4 scale plane. I got as far as doing the first elevator and ran out of the narrow tape. I still have a couple yards of the wide tape left, and the new order should be here any day now. The elevator was covered with yellow Solar Tex to try and use up the scrap pieces from previous builds, pinked, and then shot with the first coat of primer & paint. The painting really helps show where the pinking tape isn't stuck down well enough, and after a few days of curing I can simply go over it with the trim iron to fix the problem. I really can't wait for the finish color to go on, and this should look so much better than the original MonoKote shiny covering.
This is the first test-fit of the wings with the main mounting hardware. The big concern was if the pieces would fit too tightly for the bolts to go in once I added all the covering, pinking, and paint between the wing halves and the center section. Only one screw was a little tight, the rest fit perfectly.
Again, after a single coat of primer & paint there are numerous spots where the pinking needs some attention, but overall I really like how it's turning out.
On a different note, if you find yourself mixing epoxy regularly this is a handy "tool". In the past I laid down a wide piece of tape on the workbench and mixed it there, but that meant transferring from the tape to the project and risking drips while transferring it. I've also used small mixing cups, but they can be "tippy" when my mixing stick is sitting in the cup. My wife works in a dental office and she told me about these little mixing pads. Basically, they're like very heavy duty Post-It Note pads - mix on the pad, apply to the project, and then tear off & discard the used piece. They're fairly cheap and work great.
