Adam Buildtip
Hi,
today my 1hour build will be "automatic elevator".
You can use it for smoother turns without dropping your plane too mutch (thats the theory )
make your rudder with smooth moveing parts
be sure that also your elevator has also smooth moving parts
take some wire
bend it
put the wire between the rudder and the elevator
take a string and put the string trough the wire
one end of the string glue on the rudder and the other end of the string glue on the elevator
if you would glue the string on the elevator to the text ,,less,, you will get more elevation and when you glue the string to the text ,,more,, you will get less elevation
Now some photos of the build and so......
I want to continue this new serie so pleasa do not be shy and give som advice for some new project
Thanks,
Adam.
Subscribe and ask
take some wire
bend it
Thanks,
Adam.
Subscribe and ask
