Ok, so here are pictures from my pushrod woes over the last 2 nights.
I'm rather ashamed to even admit that this was my first attempt at tail control pushrods. The elevator doesn't look too terrible per-say, except for that rather extreme slope from the servo to the sleeve. The rudder control is just...well...I don't know what I was thinking other than I had hoped with just how flexible this pushrod stock is it would be ok. It wasn't. The servos here did not like this at all and would bind up and whine.
I attempted to fix this by adding foamboard standoffs for the sleeves:
This helped a lot, but I still have some issues with buckling.
Here is the aileron, Initially I was trying to not use the sleeve. When I built my FT explorer sport wing and used the FT speed build kit provided pushrod stock it was larger diameter and stiff enough that I could run it from the aileron servos to the control surface without a guide sleeve, I had hoped I could do the same here with this pushrod stock but again it's just too thin and too prone to buckling. So I tried to use a section of sleeve and a standoff made from foamboard.
The issue here is that now the system is too stiff and the servo binds up and whines.
I'm actually considering completely re-orienting the servo within the wing and laying it on it's side instead of poking out like I currently have it mounted. It means a bit of wing surgery but hey, this is prototype stage and now is the time to figure this stuff out.
The reason I had envisioned mounting the aileron servos like this in the first place is because this is how they are done in the FT Explorer sport wing and it makes the hole in the wing very simple.
Laying the aileron servo flat on it's side for mounting means taking 1 of 2 possible design routes. If we keep the full underwing (no undercamber) then we have to have a larger cutout in the underside of the wing to accommodate a servo laid flat. However, if one builds a wing with an aggressive undercamber cut the servo can be mounted flat and nested inside the wing with the control horn screw easily accessible.
I'll mock up what I'm trying to say in SolidWorks later today to better explain.
