Looks great, @Mad_Mechanic! I build things really fast but make up for it by spending three times as long as everyone else putting in the servos, horns, and pushrods. I really want to get some of those smaller servos now though. I had so much fun flying your plane that I wonder why I build so many bigger models.
I'm not sure you'd want to push the wing back further, since it would shorten the tail moment and reduce the control and stability effectiveness. On the beta plans there's 25mm between the fuse and the horizontal stabilizer, so why not just add 20mm to the nose and shift it all up? My balance problems might just be due to using heavier servos and the smaller battery (your 1300mAh easily weighs the 10g needed more than my 950mAh). If my math checks out, the moment of adding the 10g to the nose would be eliminated if I could just move the motor, battery, 12A EMAX ESC, and receiver forward by 15mm. Hey, I've got an idea, I might just add on a short 15mm bit to give it a try.
I think with the rudder you could just extend the front of the v-stab forward 5mm, and extend the line until it gets to the same point the old one did like this:
That increases the whole v-stab, but it makes the control surface area about 15% bigger without requiring any other changes-- the tab just extends over the fuselage slightly. That should be enough. It's pretty close now, but you see when I go vertical and go full rudder it doesn't quite have the authority to flip around. The 15% should make up that difference.
You can tell by my nose that I definitely need more thrust right? Someone's gotta show the ground who's boss.
Actullay "using the table as your friend" made it super simple to fold up. I have seen smaller sections less then a quarter that size go together just as easy.@BATTLEAXE - I toyed with the idea of cutting out a larger portion of the bottom fuselage to recess the wing as you had done but I was concerned that removing that much material would invite issues with folding and maintaining alignment of the fuselage itself. It would make for a smoother airframe though.
Interesting choice going with a box spar. I did the C-fold spar because I had done those building my FT Explorer and new they were simple.
One way to help new builders get the wing shape correct could be to add additional spacers or spar sections to the wing out beyond the aileron servos, but this adds weight and we would need to find adequate real-estate on the foam board sheet.
Overall though I love how people are already starting to build this design and are playing with modifications. It makes it more of a community design that will hopefully be a very good plane.
Im thinking that if there was a few inches off the lower wing panel at the tips it would take bound up stress from the LE fold and let the wing stay in a more consistent shape, be easier to fly at slower speeds for beginners (the people that would really find this plane appealing), and save on weight and FB.Yeah that's looking awesome @BATTLEAXE, I like the bigger cutout so everything sits flush, the skewers, box spars, all great ideas! It's such an elegant simple design that it is easy to customize and try new ideas. If things go horribly wrong, then you're just out of the game for a couple of hours while you build a whole new plane.
I wouldn't worry about extending the spar past the servos. The wing is short enough that it is pretty easy to fold accurately-- and this is coming from someone who always ends up with one wing a slightly different size than the other.
Aerodynamically should the CG be where the wing creates the majority of its lift in flight or is it more complicated then that?... and where on the airfoil is that lift majority created? I'm actually wondering cuz i don't know how that works exactly. Most models are mid spar, some with a swept wing will be behind the spar at the root of the wing which all makes sense if my theory is correct, but it feels like i am missing something. Do you have anything to help shed some light on this for me?Approximately mid spar is where I had intended cg in Solid works, but you my need to play a little from there to get desirable flight characteristics.
I'll mess with removing some of the underwing like you suggest in SolidWorks today and post up some revision images for review.
Hey you already built your wing right? Did you notice the wing profile root to tip issue as well or did servos in the wing help keep it consistent? If it did stay consistent for you I probably should have extended the spar an inch on either side to make up for the lack of servos... it's a thinker.
