Hi Guys,
Thought I'd share something about my relatively large Tarot fy680 Hex.
The specs say that the largest prop size is 12 inch however since I upgraded the motors to some 700kv pancake and run 4s I figured I'd order some "cheap" 13 inch props from helipal.
They arrived and I fitted them and there is about 5cm clearance between the prop tips which is resonable.
The flight is briliant, the thing hovers at around 30% throttle with a gopro and gimbal and at around 45% with a NEX size'd camera and gimbal and with the gopro setup and a 6000MaH battery gets around 10 minutes before droidplanner starts telling me battery is in negative % capacity.
Flying on the big props is really great, it has so much lift, I would love to know what something with 18inch props would be like.
The negative is that there are more virbrations even after carefully balancing the props, I think it's just due to the bigger mass being swung.
I made a video, watch to the end, it's worth it.
