Ryan O.
Out of Foam Board!
I wanted to build something huge for next years Flite Fest and I don't want it to crash. I asked Stefan at Flite Fest wether I should build a giant Shinden or a giant Pun Jet, and he said that the giant Shinden would probably fly better, plus I could enter it into a nearby giant scale warbird event. I haven't stared building yet because i'm not sure if they will come out with the monster foam or not. The motor that I had in mind was this one https://www.hobbypartz.com/66p-188-gt5325-11-kv260.html. I am either going to power it off of 6s or 8s. This is my first large electric build so I don't know which battery size would be needed. I will build it with the foam molding techniques for the wing and most of the fuselage because it will be more scale. The main thing that I am not sure about is how to put the retracts in with a long enough landing gear wire that won't flex. the Full scale had really large landing gear and I don't know which type of metal rod to use
. It will use the same dowel spar system as in the giant Spitfire and Cruiser from a while ago. It will probably have the center of the wing permanently attached for strength and the ends of the ing will come off. The other problem is I have no idea where this will balance because it will have an airfoil that isn't eliptical unlike the real one. Thanks for any help.
Upload.wikimedia.org. N. p., 2019. Web. 15 Sept. 2019.
Modelingmadness.com. N. p., 2019. Web. 15 Sept. 2019.
