Hello RC friends,
Sorry for my english, I`m from Germany.
The story started last spring when i first saw David`s tricopter. I was amazed and had to build it.
So I bougt thes tuff i need from HK. As a transmitter i chose the Turnigy 9x. It had the V2 firmaware on it.
When I was done with the build I flashed the Speed Controllers with SimonK`s firmaware. No problem there, i teached the controllers with the 9x and they where running. But they didn`t arm when they where connected to the microWii controller. I tried so much, measured all kind of stuff but nothing helped. So I thought there was something wrong with my transmitter. And actually through all the readings about multi copters everybody said: flash your transmitter. So I did. I wired it up, checked connections started up eePe chose the right options and hit the flash button.
At the end I got a massage that said: contet missmatch. AVR dude did not finish correct.
The 9x won`t turn on any more. I can flash it again and it seems that my programmer has a connection to the Transmitter but I always get an error and the Transmitter seems bricked.
I put a picture from eePe after flashing to this post with the error massage.
I hope somebody can help me. I`m so disapointed.
Thank you very much!
