bracesport
@BATTLEAXE - time to get that drone in closer for some chase footage!
I need to be flying slower. Or a slower flying plane for him to keep up to just cruising speed. The RACE mode on his drone will do 60kph. Maybe the wing will slow down enough. He could chase me in the Sportster, never tried. I probably could have that going a lot slower.@BATTLEAXE - time to get that drone in closer for some chase footage!![]()
If you want speed try flying 4-5 feet off the ground. @JGplanes white diamond that I fly a lot, is not particularly fast in open air but when you are close to the ground, man does it look like and feel fast. You have to react very quickly to keep it in the air so it keeps you on your toes and when you start throwing in lots of consecutive turns...what an adrenaline rush!!When is it ever fast enough![]()
Good suggestion... but I already have a fast plane. Close to the ground and in the air, lol. And it definitely pumped the adrenaline. Fastest most powerful plane I have flown.If you want speed try flying 4-5 feet off the ground. @JGplanes white diamond that I fly a lot, is not particularly fast in open air but when you are close to the ground, man does it look like and feel fast. You have to react very quickly to keep it in the air so it keeps you on your toes and when you start throwing in lots of consecutive turns...what an adrenaline rush!!
My Charlie will be more of an all arounder/ stable basic sportster and possible onboard camera platform, but I've got a need for some speed in my fleet too now. My new slender delta delivers huge for an 1806. I'll try to get some longer full throttle passes. My '39 special and Vulcan have a high top speed, and the Arrowhead is no slouch either, though a bit slower. The slender delta tops them all in top speed though! Most of the other planes on the same motor are pretty quiet, but at full throttle that thing screams! Any more speed and it'd be a bit sketch for my flying field size to fly full throttle, its just right and a bit hair-raising. With properly scaled thrust to weight and size, I'd like to see what a slender delta could do with a really powerful setup. Maybe a big high KV motor on 4s with a smaller diameter, extra aggressive prop. Maybe we should go for broke and try some of our custom designs or scaled up Trifecta jets @CarolineTyler style with a 70mm EDF on 6s that goesGood suggestion... but I already have a fast plane. Close to the ground and in the air, lol. And it definitely pumped the adrenaline. Fastest most powerful plane I have flown.
I just have to get it out of a tree tomorrow.
The Graupner motor with the 6x4.5 prop will be lots for the Charlie, especially how you want to fly it. It will have more torque, even with less rpm the higher pitch on the prop will make up for it. And it will be nuts on 4s, hang on to your shorts kinda nuts! Given what I got outta mine and what @The Hangar has done to his, you are guaranteed to enjoy yours.So I've got a 2806 Graupner 1900KV motor I could use for the Charlie, compared to options of getting a 2806 2300KV or FT Radial 2205 2300KV I can buy for the same price. I plan to use 6x4.5x2 bullnose props, and most likely run on standard 3s, though I'm half tempted to try 4s. I'm thinking the higher KV motors would be more efficient?
Lol - story of my life...When is it ever fast enough![]()
Awesome! I’m going to fly my bravo tomorrow hopefully, and I’ll definitely be getting video! I can’t wait to see how the Charlie flies and what you think of it.Ordered all my stuff for the Charlie, should be here in a few days to a week. Going to try some Lumenier 6x4 slow fly props with the 2806 Ultra 1900KV motor.
Awesome. This thread is going to get a resurgence soon. I really want to get the Charlie flying good because I haven't seen a single video of somebody really thoroughly flying it. It's probably actually a really nice bird, maybe more will want to try it if I make it shine.Nice, once I finish my Spit I'm going to jump back in to the Alpha.
I like how excited you are getting on this one! I am sure once you have it built you will really want to fly it, then once you fly it you will want to push the boundaries out some and fly it harder then the Nancy's you have seen in the vids. It will be a welcome change to the usual flying platforms I have seen from your hangar. I am really anticipating the build and the maiden, it will be fun to follow and watch. Even more fun for you to fly it.Awesome. This thread is going to get a resurgence soon. I really want to get the Charlie flying good because I haven't seen a single video of somebody really thoroughly flying it. It's probably actually a really nice bird, maybe more will want to try it if I make it shine.
It will definitely be refreshing! I spend a lot of hobby time on custom work and have limited storage space, so I choose my FT birds carefully to be unique and round out my fleet by filling a niche I don't have and probably wouldn't attempt to build or design myself for a while to come. The DR1 is a good example of that, being completely different from the other planes I have. In fact, I am going to go check the wind after this and see if I can test that 5x5.5x3 Hulkie I put on the other day properly. The Charlie is a stable, all-around prop in slot jet with basically what amounts to a forward swept wing, or a compound wing with a delta/LERX thing combined with forward swept tip or canards or however you want to refer to it, so it's something new to meI like how excited you are getting on this one! I am sure once you have it built you will really want to fly it, then once you fly it you will want to push the boundaries out some and fly it harder then the Nancy's you have seen in the vids. It will be a welcome change to the usual flying platforms I have seen from your hangar. I am really anticipating the build and the maiden, it will be fun to follow and watch. Even more fun for you to fly it.
