Yeah doing the nose cone is best when you do it like in the build vid. The top and bottom halves need to be slowly glued together a inch or two per side at a time, meaning you start at the tip, glue an inch of one side, line it up, and hold till cooled, then do the other side only an inch. Line it up so the two sides are symmetrical. then go back and do another inch on the first side, repeat the same on the other side and hold it to be symmetrical and so on. As you get further back you may be able to do more then an inch at a time. And do lots of dry fitting to make sure the seams come together evenly, just so you know where to trim a little more bevel or not. If you take your time it should come out clean and even. On the seams after it was complete and cooled I even sanded off the excess glue that oozed out with 100 grit the smoothed it with 220 grit. Mine almost looked so nice that I didn't want to fly it knowing it would take a nose hit at some point. Pro tip- take pics before the maiden, it will be the prettiest it will ever be lol
