Aero L-39 Albatros - 50mm EDF jet
jfaleo1
As promised this is my newest. 6 blade 55mm EDF. Ironed LE and TEs. Opened up area inside inlets more and replaced straight former mid wing with a “V” angled former to direct cleaner airflow and last I put in angled close outs in the nacelles to direct airflow to the fan. The airframe is basically otherwise stock in black DTFB, and the newer green DTFB
Grifflyer
WWII fanatic
. View attachment 152295
That looks SWEET!! Can't wait to see it fly!
IcedStorm777
Could i use a 64mm with the original size plans as that is all i have and possibly for more speed/thrust. If not what scratch built 64mm EDFs are available? Thanks!
jfaleo1
Griff is right. No chance 55mm required mods and it is a REALLY tight fit. Check @Zephyr1 like Griff said. I’m not sure what else is on here in that size, sorry.
whackflyer
That green stuff came from DT?😍😍😍
jfaleo1
I thought since I posted the pick of the modified black and green version I would also post what I did to modify the inlets. The pictures show the same modification on a new 70mm version. The “v” former is basically a double wide version of the original straight one trimmed to fit the wing opening. The inlets are opened most of the way forward. And I put in angled close out pieces to direct all airflow to the fan. I hope all this will improve efficiency and make them a little faster.
For what it is worth that is a 6s capable 70mm fan, and I am putting on the racingwing tips.
😁 DDA4D43D-CD66-4970-AF45-B8A8378D5502.jpeg 82D98AE6-5AEE-4FD4-AD7E-59D54D81D83A.jpeg 779A1C22-4E62-4921-B3F2-75B33B3C3BF7.jpeg
Grifflyer
WWII fanatic
😁 View attachment 153244 View attachment 153245 View attachment 153246
That looks great!! Let me know if you notice any difference.
jfaleo1
I will as soon as I get time to fly. I currently have 2 L-39s, 1 Mini Guinea, 1 standard White Diamond, 1 200% White Diamond,
1 Arrow, 1 Speed Deamon, 1 Baby Bugatti, 1 Moni, plus this 70mm L-39. All to maiden next time I get to get out and fly.
The L-39s and White Diamonds are top of the list though.
jfaleo1
I forgot an FT Bravo and a modified MiG-3 as well🙄
Ryan O.
Out of Foam Board!
Cool. I didn't even know they made 50mm systems. The L-39 looks sweet when the curves are changed to low poly.
leaded50
on 64/70mm version its should be to only adjust plansizes accordingly . Do the plane a touch lagrer to get that edf´s to fit.
