Hey friends! At Flitefest 2019 I worked on a project a friend had designed. He drew out some plans and gave them to me. I translated them to foam board and tried to make it fly. Well, it didn’t. There were a number of issues:
1) it was heavy. I am usin 1808 motors on 3s, so I have plenty of power but more weight means you need more airspeed to keep it in the air.
2) since the motor nacells in the design are so low, you need a bit of down thrust to compensate for that. I didn’t have any making it loop upon launch. Fixed it there.
3) I had accidentally made my nacells slightly crooked, so my plane always wanted to pitch right.
I plan to redo the wing and leave the fuselage since i spent a while painting it and I’m pretty happy with how it turned out😉. The tail got a little banged up in transportation and storage, tho that will need some work too. I have the plans I used and will try to post them just in case anyone else wants to join along! (Please do!) It is a pretty small plane - just a tad bit smaller than the mini guinea pig.
NOTE: progress may be slow as I’m working on several other airplanes right now😂
