Shurik-1960
A package arrived with servomechanisms wire extensions, installed and sealed the top.I wrapped it with duct tape and an iron.
I'm a little disappointed- the model turned out to be heavy. The wing and top of the model would have to be sewn with foam 3mm thick.
The weight of the airframe is 520 grams, the weight of the battery is 180 grams, the planned weight of the regulator + motor is 100 grams.The planned flight weight is 850-900 grams.
Based on the planned flight weight, I am looking for a motor that I will order on aliexpress. I will seal the bottom after installing the motor and regulator . The battery will be inserted into the nose through a hatch in the lower part of the fuselage.
