Rumpleman456
so im gonna be putting an ft aura 5 lite in a carl Goldberg anniversary piper cub, which is a tail dragging aircraft. will i need to zero the aura while holding the tail up as if the plane were in level flight?
also how would i reduce vibration of the board? im nervous that it will vibrate and throw off the gyro
flyingkelpie
I reckon that would be right. For vibration, I would simply be sure your prop is balanced well and other than that you should be right. Also, try looking at some of the FT Tech videos on the Aura.
I don’t have an Aura.
With my stabilizer, you need to hold the tail up to establish level. You only need to do it once for calibration, not each time you turn it on. My stabilizer comes with a small piece of foam to mount with, which has worked well.
