Hi all, I've been having some real trouble with setting an aura lite up for a V-Tail configuration aircraft. I can't find much of what the difference is between the "VTail A" and "VTail B" types on the aura configurator, but they don't seem to do anything different on the plane. This plane is a FT Tutor that has been converted to a Vtail configuration, so there are Throttle, Ailerons, and then the two ruddervators as far as outputs go. The biggest issue so far is that when I have the Aura setup with CH5 on the TX controlling the flight modes with Manual (gyro off), 3 axis, and 6 axis-stabilzed as the three modes, I can't figure out why I have much more throw on my ruddervators in the 3-axis mode than any other flight mode. I've been poking around in the configurator tabs, but haven't been able to change anything that seems to make a difference. The transmitter that I'm using is a "bare" model, no mixes, rates, etc setup at all, and the plane was flown with it before (with the stock/standard tail). I'm unsure where the issue lies, does anyone have experience with using the Aura on a V-Tail?
