happyman88
I seem to have run into a snag building a bat bone tricopter i am using all recommended parts from the plans on the store except the escs are 30 amp instead of 10 or 15 amp( just what was in stock at the time) . The issue is that on a fresh charged battery all 3 motors will start spinning i can take it off then anywhere between 2 to 6 minutes into the flight 1 or 2 motors will just slow down to the point where it crashes. I have checked the voltage in the battery after this has happened and it is not anywhere near where the low voltage cut out should activate and i believe that i have programmed them o that there is not a lvc. This issue has cost me a motor and a few props and any input would be great.
Thanks
Thanks
