Bavarian_RC
I was still not sure about how to make the wing attachment using screws. So I decided to test build the center section of the wing and see how it could work.
Note the small square cavities in the lower skin. I added small plywood squares inside in order to reinforce the section where the screw head will rest on the outside. When tightening the screw it will not compress the material below. The other plywood reinforcements connect directly to the front and aft spar which should lead the forces from the attaching points to the spar.
Here you can see the 3 nylon screws (M6) and the drive-in nuts which will be glued to the fuselage.
I had to adjust the plywood parts with the Dremel to make room for the drive-in nuts... really looks like a mess
. Finally the lower plates with the glued on drive-in nuts are attached to the rest of the plywood structure. Quite a bit of effort to make this section strong, but I guess this is necessary as the wing is screwed only to the lower deck which has no supporting structure of the fuselage in the forward part. Hope it will be able to take all the loads coming from the wing… and my landing skills
