I maidened the Heinkel 219 today. We had cold but very calm weather (and no fog), pretty much ideal! The good thing first: it is still in one piece! The sketchiest part of the whole flight was the launch. Right after the start it pulled up almost vertically and I had some scary moments until I had the trimming done and the Heinkel back under control. After that it was behaving really nicely.
It showed no bad tendencies during the flight. I would even say that it is incredibly stable. I was trying to stall it, but even with full up elevator it was not stalling, but only sagging slightly.
Last impressions taken before the flight (you never know
And some pictures from the maiden flight
I also did a short video of the maiden flight
I am still wondering what caused the high amount of down trimming that was necessary to fly level. I had to use all the travel of the trimming which is about 3mm down at the trailing edge of the elevator.
When I tested the CG in flight (vertical dive without power) it was not recovering on its own but even going more negative. This is typically a sign for a CG too far back. But I was on the forward edge of the calculated CG range at 55m from the LE. Maybe I need to check again the difference of AOA between wing and horizontal stabilizer. I will do some investigations and more test flights in the next days. But for now I couldn't be happier with how the maiden went.
