I picked up some CF 8045 props from HK for my last build and I have been very happy with them. They're paper thin, weight nothing, very rigid, and have taken quite a number of run ins with the ground, bushes, trees, metal poles, and plastic poles. So far I have only put a crack in two of them, which has happened after hitting the plastic or metal poles. They were still 100% flyable and I only noticed the cracks when I was making sure the prop nuts were still tight.
CF props are more expensive, but I am very happy with them. The light weight means they don't carry a lot of inertia and survive much better than I had expected. Some of the crashes into the ground, bushes, or trees would have busted the composite carbon reinforced nylon 1045 props I've used in the past right at the hub, sheering the blade clean off; obviously not flyable when that happens.
