Just printed the plans. Looks like an easy build and fun flyer. Strix, any chance you can take a picture of your landing gear do I can see how it's mounted? I'm thinking of mimicking the gear from the bushwacker with some oversized wheels.
Yes, it's a very easy build! And I'm extremely proud of the landing gear I've come up with for this model. I've been meaning to make detailed instructions for it, and since you asked...
It's made of 4 pieces of 1mm music wire, which is very easy to work with. A single piece isn't nearly strong enough on its own, but the way they are interconnected makes the landing gear assembly quite robust.
The axles are bent thusly (don't forget that the dimensions are for a two inch wide fuselage. Add an inch to the top sections of the leading and trailing axles for a 3" wide fuse):
The end section of each piece of wire goes through the wheel's axle hole. So the wheel actually rides on a 'composite axle' of sorts, made up of the end section of each wire, all tied together with a 3/32" wheel collar:
To assemble, attach the cross axles to the leading axle. Use a small amount of clear tape at the axle end, and at the other end, bind the cross axle to the top section of the leading axle with some thread and CA.
Then glue this assembly to the leading edge of the fuselage's bottom plate. It should be perpendicular to the fuselage bottom. A popsicle stick or wooden coffee stirrer should be used to reinforce this attachment point.
The top center section of the landing gear extends past the edges of the fuselage, so you'll need to cut some small notches in the fuselage sides for clearance. Fill the notched areas with hot glue to help secure the gear. This will also ensure that some of the load from the landing gear is transferred to the fuselage sides, and not borne completely by the glue holding the axle to the leading edge of the fuselage bottom plate.
Then attach the trailing axle to the ends of the leading axle with a small amount of tape. The axle wire will rotate pretty easily around the taped ends, and should contact the fuselage bottom plate approx. 1.75" behind the leading edge.
Because of variances and slop in the gear assembly, it is best to not cut the slot for the trailing axle until the leading axle has been attached. Line it up so that the wheels will track straight. The axles need to have a slight amount of toe-out in the wheel alignment. Toe-in will likely cause ground handling problems. (Use The Google if you don't know what toe-in and toe-out means.)
Once you have lined everything up, take a pencil and mark the location (and angle) of the trailing axle. Cut two 50% score cuts 1mm apart 1/16" forward from this line, along with the necessary notches in the fuselage sides. Then remove the foam between the score cuts and glue the axle in place. Make sure to fill both the slot and the notches with glue. It certainly wouldn't hurt to reinforce the opposite side with a popsicle stick or wooden coffee stirrer.
Then attach the landing gear covers, which are made out of posterboard. The covers should overhang the axle assemblies just enough for them to be glued in place, and they should be flush at the fuselage end. They should completely cover the ugly notches that were cut in the fuselage sides.
Here's a view from the bottom:
Lastly, put the wheels on and attach the wheel collars.
You can see a small amount of accordioned heat shrink tubing on the axles there. This was my original method of binding the axle ends together, but the 3/32" wheel collars wouldn't fit over all three axles with heatshrink over them. The collars fit just fine over a couple of layers of scotch tape. 1/8" wheel collars would probably fit over heatshrink with no problem.
I hope that's plenty clear enough. Sorry for the less than stellar PNGs from my CAD program.
I'll be publishing full PDF instructions later, since I'll need them to help my clubmates build their BJ-J3s.
