Mac82
Foam scraps? I got plenty
Here I go again,
Ok folks I'm bringing y'all a build log on ( you guessed it) a J-3 cub. I finished about 95% of the plans now transferred to the foam board in kit form
I'll be building this balsa style built up and reinforced with balsa or ply where needed
I've used about 2 1/3 sheets of foam board, I probably could have used a little less but I was trying to use up some scrap sections I had laying around.
I've only got a couple of the fuselage tail formers the landing gear and cowling then she'll be ready to cut out and assemble.
As you may noticed I've got the wing set up in ribs. This is going back to my earlier experiment with the built up wing with balsa foam and poster board seen here
http://forum.flitetest.com/showthread.php?21587-Foam-wood-paper-built-up-wing
But instead of using the poster board to cover the entire wing I'll only be using it on the leading and trailing edge. The wing tail and fuselage will be covered with monokote in cub yellow( again something I had for another project that didn't get used).
Thoughts, concerns, critiques always welcome.
I'll be updating you as the build progress.
Thanks for stopping by.
