I'm not getting any lift out of this set up. I lifted it up with my fingers and it still felt like 3 ounces.. I have a few more test I'm mind. Back to guide test for starters.
Like using a leaf blower to get reactions from the plane. It seems like this plane needs more wind than my leaf blower can make. I'll try and make more wind with help from a wet dry vac.
So a couple of things going on here in the last few days.
First off shout out to @d8veh. Great instructions for a glide test.
@Txwarthog you mentioned you are not sure if you are doing this right. At this point you have totally destroyed your first Tiny Trainer. You have tested balance and control directions and have glide tested this plane to a 'fare thee well'. Your frustration level is just below the limits of what you can take and you have 5-10 people reading and pitching in to help.
I would say you are doing EXACTLY what is needed to get into the air. Everyone goes through this. Pilots are the ones who stick it out.
Here's a hint. Most people who quit, do so within sight of their goal. You will never be closer to quitting than just before you win.
Never mind the bent plane and the foam bits. No one's first Tiny Trainer is straight. All of these models eventually end up in a bag with the electronics torn out for future use.
The model doesn't matter. It never did.
"Success is not final, failure is not fatal: it is the courage to continue that counts." Churchill
This is what you came to FliteTest to learn.
I say you are doing great! Keep it up!
You will both have many successful flights I believe in you both. Just remember trial and error lead to the real deal. You should both look at the thread I started when I began and see what I went through till I started flying.
You will learn to build and fly as long as you keep at it and do not give up.I do not want to steal this thread. You've got help us out though, with a link to the thread you are mentioning.
The new plane is here. My thought right now is if my DX4e can be set up for a V tail. Does anyone know? I will build it, but looks like really poor weather for the next 5 days here in Dallas.
I think it would require some sort of special setup because the v tail will act as both the elevator and rudder. If you move the right stick left/right the both halves will shift to the left or right together to rotate the plane, if you move the right stick up or down, both sides will move opposite directions left and right or right and left to move the tail up or down. If that makes any sense.As for as I know it has nothing to do with the shape of the tail because ailerons are ailerons no matter what tail the are on. But still I’ll be waiting for more feedback because I also have a DX4e transmitter.
opposite of an elevon where they move opposite to bank for turning and together when controlling the pitch.
It appears that the DX4e only supports elevon mixing, (Elevator and aileron). though if your "V" tail is for 3 channel operation only then the aileron channel can be used as the turn, (rudder) and so a "V" tail can be implemented.The new plane is here. My thought right now is if my DX4e can be set up for a V tail. Does anyone know? I will build it, but looks like really poor weather for the next 5 days here in Dallas.
I think you’re reversed on both axis’s. When you push up, the rear surfaces should go down. When you go left they should go to the right when the plane is coming at you like you have it sitting there.This looks correct to me. I can make a video if that would be more helpful. I wanted to start a new thread, and still plan too, just wanted to make sure it wouldn't be a dead end. I'll start working on the power pack if everyone agrees my controls work.
