Hey all, Yes I'm new to RC Airplans. Just scratch build the FT Mustang with a 1045 prop, 3s 1300mah battery, 30amp ESC and a 935kv motor. Using a DX5e and AR6200 spektrum receiver. The first attempt to.maiden it pulled up the tail and tipped over to the nose and busted the prop and broke the landing gear. The 2nd attempt was a toss and it straight into the ground. The 3rd attempt it spun the prop right off. It's a little nose heavy cg about 35% back on the wing...all throws are in the correct direction but it still wants tip forward. Could it be under powered, wrong props? I'm not sure. If anyone has any idea what to look for or try it would be much appreciated.
Thanks,
Jeff
Thanks,
Jeff
