Covering foam board
I was following this guy, who was using 2" thick foam insulation, then cover with brown paper. He has a complete tutorial on how he does it.
I was planning to build one before I stumbled across FT. He had a neat trick for hinges. Take about 2" of regular string, put some CA on it to make it hard, poke a hole in the foam & insert the string, then hot glue them in.
MarkPrima
I use the pink foam for my wings, after a good sanding of the foam i apply Polycrylic to the foam and thin brown paper and then apply the paper to the wing and roll out smooth. Works well and have no issues.
mdcerdan
Does anyone cover their foam board planes with light brown paper and thinned pva glue?
I cover my Styrofoam planes with poster paper and 50-50 white glue. No need to paint if you use the colored paper.
Then I cover the paper with clear laminating film.
All my planes are 1.2m wingspan and weights about 600g with battery
This are a few planes I made this way.
