I still kind of regret taking my MMU out of the box and installing it
I do seem to finally have it working mostly reliably. But my Mk3 went from being amazingly reliable to nothing but trouble when I added the MMU. After re-building the extruder again I finally had the printer with MMU working reliably:
But don't see myself using the MMU much. It's so wasteful - the purge block on this print weighed more than the print. And it turned a 2 hour print into a 8 hour print by switching it to 3 colors. And honestly I don't print things for "looks" I print for functionality. And the only prints I've found that need the MMU are just for looks. At least my daughter appreciates it
The main reason I wanted the MMU was for soluble supports - but supports on the Mk3 print so much better and are so much easier to remove than on my old printer I haven't felt the need for soluble yet. And soluble material is crazy expensive and needs to be stored in a drybox which is more pain/expense. And with the MMU not being super reliable for me I've been hesitant to risk the expense of soluble material.
And I had my printer setup with the lack enclosure which I loved but with the MMU it no longer fit. I just finished the new v2 lack enclosure but that was a solid week of printing and when I put the printer back in I managed to get one set of power wires swapped around. Thankfully it seems I didn't kill anything...but after the jostling and moving of getting into the enclosure the MMU is acting up again and working on it inside the enclosure is way more frustrating.
Oh - and the instructions on the v2 lack enclosure IMHO have you cut the PTFE tubes a bit too short. I cut them exactly as long as suggested but it puts a pretty severe bend on 2 or 3 of them which I suspect is a big part of why the MMU is acting up now. So I need to order more PTFE since it's kind of hard to make things longer once they've been cut
