Well, I'm 40 hours closer to having a machine!
Did a quick test fit with some screws and conduit to make sure they're the right size
I have to admit part of me really wants to source my own parts so I can buy them as I have a bit of money available. But the $240 set sure looks nice so I'm tempted to save for it instead.
But I have more than enough 6/32 3/4" screws now
Oh well, always good to have more screws in the spares bin
Also. I went with dkj4linux's dimensions "36" x 48" footprint, 25" x 37" active working area." which seems like a good size for working on foam board. Just two problems with it:
1) I only bought 2 10' sticks of conduit which is 240" total. And a 36"x48" machine uses 297" of conduit. So I need another stick. Hardly the end of the world though, a stick costs about $3.40 here which is nice because wood here is considerably more expensive than what I was used to in Ohio...good to see metal is still about the same
2) I had planned on being able to put this on my dining room table. But...that's not going to happen
At a minimum I'd have to create a larger false top for the table to fit this. Looks like I'll have to build a wooden table to go with it as well - and make that collapsible so I can store it when not using the machine.
Oh...and those zits on the prints...I've seen those before but only very occasionally. They're very consistent though and happen in the same spot on every print. I believe it's because of my retraction being off. The high infill on these is causing a lot of retraction moves and those zits seem to show up right where a retraction move happens. Problem is these are kind of long prints to use as tests..and I don't have any smaller models that do that consistently.
So After the last block finished printing instead of moving on to the rest of the pieces I sat down with openSCAD and made a solid 20x20 block to test print. I only printed the first 6-7mm or so but sure enough I was getting the zits on it and I don't get them on 20x20 hollow cubes. Adding an extra 0.5mm of retraction and changing slic3r to do external perimeters first seems to have cleared it up on the tests. I also disabled "retract on layer change" and "Wipe while retracting" which I had turned on trying to deal with little balls on the outside of my prints with PETG. It helped with that but seems to be making this worse.
Not convinced my test piece really made the problems show up though. So started designing a test piece with some holes through it and shorter (so it prints quicker). Seems like it makes the problem more apparent...but think I can do a bit better. So added some curves to the outside. And I'm too tired to do any more test prints tonight
Hopefully tomorrow I can confirm I've got this issue licked and then continue with my MPCNC parts. Oh yeah...need to order another roll of PLA too this one is already getting kind of light. Wonder what color will go well with purple....I should just get black because I could use black for some other things too...but I'd kind of like this to be a bit more colorful than that
