That's another thing I have been trying to work on. I have a very small/light action cam, but to get a good view of the entire rear of the aircraft I have to mount this thing like 3' off of the back. Even as light as it is, it still plays havoc with my cg way back there. I need to look at these small quad cams and the lightest carbon fiber rod I can find to mount it on.
Aye, she will be a 50mm EDF first. I will also make a prop option and I have a few ideas on how to do that with such a tiny frame and still look scale. A standard prop and slot is out of the question, and I don't really care for pushers. Who knows, I might just have a pusher and/or third option which will have two tractors on faux wing tanks. (super bee style)
Update: Self adhesive paper test 1
I got my first batch of paper in the mail today, this stuff here...
Online Labels @ Amazon
So my first test results are as follows.
Standard 8.5x11 20lbs copy paper: - 4.5grams per sheet (This is what my Rhinos are made with)
Standard 8.5x11 24lbs copy paper: - 5.4grams per sheet (This is what I normally use at home for my pencil sketches)
Online Labels 8.5x11 label paper: - 5.7grams per sheet (This will be tested on my next prototype build)
One thing to note, the label paper has the adhesive applied already and the other two are dry. So I would say the Online Labels paper is equivalent to 24lbs copy paper. I have not actually tried to stick this to foam yet, but when I pulled the backing off of the paper to test the weight, this stuff is sticky as all get out. I think this could be a great way to skin these planes without the spray adhesive.
I still have two more brands en route and should be here by next week. I will test those as well. I will keep you posted on print and adhesion quality along with the weight.
