Definitely. An advantage of using an arduino / FC is that complex sequencing and servo speed control is possible with even the most basic of transmitters.
I've got two ply mounting plates embedded into three formers (one double-thick) in the nose. The nose itself is braced to the rest of the fuselage with some gussets to take up the moment around the join between the two. There'll be something similarly robust for the main gear: plates transferring their load vertically into the wing through a box just behind the wing spar.
There's no downside to having a reversible ESC. It'll turn the normal way for normal flight and the opposite way for reverse, no loss of power in either direction.
As far as I know, variable-pitch setups (at least, those for helicopters) typically use symmetrical cross sections to reduce the pitching / twisting moment of the blades (this applies at full scale, not sure how true it is at model scale). Cambered sections are better optimized for one direction but provide relatively poor performance in the other (especially when driven backwards) whereas a symmetrical section performs the same in both directions. So the tradeoff is that a variable-pitch setup would provide similar thrust/efficiency in both directions whereas my setup with the reversible ESC is superior for forward flight and inferior for reverse/braking.
If I can get a sufficiently high lift slope with these massive externally blown flaps, I should be able to get the plane to fly level with the nose pointed towards the ground. In that attitude the nose gear will hit first. I should be able to keep the nose on the ground and the mains off. The main concern will be the positive feedback loop with the nose gear that will tend to try and turn the plane around backwards: as the plane yaws to one direction, the nose gear (if uncorrected) will tend to steer it in that direction, further increasing the yaw. Keeping pressure on the nose wheel light and continuing to fly the airplane will give the best chance of success.
