crashburnrepeat
Hi all, hoping I can get some help on this one.
I have a DX7 (Gen 2 black) and am 99% done a differential thrust setup on a Mini-Guinea. The only thing left is the throttle cut. I know its not necessary, but I prefer to usually have one.
I have left and right motors on ax1 and thr and the 2 rudder mixes on a 3 position (G) switch (0=mix off, 1=mix on). That works great, and the motors spin up separately when the mix is on correctly, no problem at all.
(The reason for using a 3 position switch is that I put the cargo door on ax2 (switch A), and i usually run my throttle cut on switch H).
When I use the usual throttle cut option on my dx7, it drops the throttle channel to -130% and works great usually, but (here is the issue) with the ax1 input running the second motor, the throttle cut only shuts down the thr input motor, and ax1 spins away.
AKA it makes no difference if the mix switch is on or off or the throttle cut is on or off, as the ax1 input/channel is not affected by a throttle cut as it only affects the throttle channel/input (as is).
I am thinking I can do another mix to fix this? Or is there a way to include another input/channel on the throttle cut setting somehow? (this is where my brain locks up and my eyes start to glaze over).
Cheers,
Scott
Cheers,
Scott
